Not that this it matters, but I was shooting on a dsr300 where I always get flawless audio., but heres my issue that I hope someone who is up on audio can help me...:
I taped a program with a direct feed from the sound board. sound checks gave me perfect audio. when the program, the audio was alittle strong.
i eventually, went with my wireless from the board and the audio was great. when the audio set up my cabling, he had the xlr cables 6"s apart from the ac feed i had into my camera for ac power.he told me later, this is crucial to do to avoic and audio issues.
with regards to my problem, after the sound check and all was well someone set up a small camcorder next to me and used the same power strip i was on, but instead of leaving it where it was, he moved it and was on top of the xlr cables. audio guy said this is what caused the problem.
after we listened the the messed up audio, he said i could use audio filters to correct the problem. now here is where i dont remember his suggestion. he said something like adusting the audio to 60mhz or remove the 60mhz something to do with this and it will be corrected.
i know the filters in edius dont apply here, i dont believe, but im wondering what programs could solve my problems? possible sound forge? others??
help appreciated.
and if youre clear on my problem and think you know what can correct the problem, details on how to do this would be greatly appreciated.
thanks
jim
help appreciated.
thanks
jim
