Another DIY zoom controller variation
ransom
I enjoyed building the original DIY zoom controller so much I came up with this variation. I'm sure it's been done before but I've haven't seen it posted. This one uses 6 momentary pushbutton switches, 2 rows for each zoom direction: telephoto and wide and 3 buttons in each row for the 3 zoom speeds. You can press any one button to directly select the speed and direction desired without having to go through other speeds. 7 individual resistors are used to select the right resistance needed- see schematic below. Resistor values probably aren't perfect but hey, it works. 3 pushbutton switches are normally-open and the other 3 normally-closed.
I think I'll build a new one with better quality switches. These are from Radio Shack and they are cheap- quality and price. Disregard the button colors as they came in red and black both in each package.
Re: Another DIY zoom controller variation
Any idea what would happen if all the "out" buttons got pushed at the same time?
Dan
The resulting resistance would be 19.44k ohms. This would result in a fast zoom in. If built correctly, any combination of buttons shouldn't present a problem. Obviously care must be exercised when selecting buttons to get the desired result. That's why a lower profile button with more tactile feel would be better.
Is my math that bad? I get 30.3K
Parallels added, then divided, then add the serieses. No?
Serieses?
The lowest value parallel is 2.2k so the parallels will be less than that. I get 1.44k for the parallels, then add the series to get 19.44. It's product over sum for 2 parallels. ;)
D'oh! Just ignore me. It has been forever since I worked at the component level. :)
Dan
I have a DVX 100A and a Sony PD 150 also.
Do yuo know a project about a remote zoom and focus controller for this camcorder.
Thank you
Newbie
Newbie
Hello, I apologize for bothering you; However, I am stumped. I have been working on the DiY Zoom controller all day and have been successful at one thing......... Zooming out (20k).
I am looking for the Mid Zoom resistance level as I want to use the buttons and not the pot.
Just thought anyone who has had this problem could give me some info.
Thanks in advance
T
My camera is a DVC 30 (Yes its the baby brother to the DVX, but, it does everyting I want it to do).
Nevermind (not that anyone was looking anyway)...... I had to break out the multimeter only to find that --------------------------------------------------- was not value they said the were..... My Bad!
