I used to cut PVC rings to make Mic shock mounts. I have strangely had alot of experience doing this.marlenedegrood said:Funny you should ask......that to me is the hardest part. I use a hack saw and try to follow my measured lines as best I can, then I lay sandpaper on the workbench and sand it. My workbench is level so I use a bubble level to get both sides parallel to each other and the cap the "connector" is going into. I'm sure there's a better way but that's just what I do.
