I am cutting together in FCP 5.04 the following:
anamorphic PAL DV
non-anamorphic (5:4) PAL DV- the equivalent of 4:3 in NTSC
4:3 NTSC DV ripped from DVD's
I have lots of subtitles to create, so I want to use a conventional 5:4 PAL DV frame for my final sequence which will allow me to letterbox the anamorphic PAL DV and have space for titles around the letterbox.
Can I use FCP 5.04 or should I upgrade now to FCP 6?
Is there a way to put the anamorphic DV PAL into a 5:4 PAL DV sequence without losing resolution? I was actually hoping that I would make the anamorphic DV appear sharper by reducing its size to fit into the standard PAL 5:4 frame.
Any assistance with these pressing questions would be greatly appreciated!
System:
17" Powerbook G4
Lacie d2 extreme HD
Thanks very much for your advice!
Paul
anamorphic PAL DV
System:
17" Powerbook G4
Lacie d2 extreme HD
Paul
