anamorphic adapter question
chi_red
Hello everyone,
This must be the simplest question but I can't figure out the answer(I am not good with Premiere)
I purchased Panasonic Anamorphic adapter yesterday.
I shot a test footage by using the Anamorphic adapter with 24P Adavnce setting, and trying to edit it by Premiere Pro 1.5
I imported the footage by using the preset Panasonic 24P Widescreen 48khz,
and the image is still squished anamorphic image.
How do I STRETCH the squished image to the correct 16:9 image?
I tried different pixel aspect ratio on Interpret Footage, but no luck making it full 16:9.
What setting do I use to import squished footages?
Thank you in advance,
Chi
In the project window, right-click on the footage and in the context menu select the Interpret Footage item. In the dialog that appears, select the Pixel Aspect Ratio Confrom To option and in the combobox, select the 1.2 widescreen option.
Then select Ok. Your footage should now be correct and dropping it into the timeline will have the correct aspect ratio.
