BrianMurphy
So I ordered two of these VERY PRICEY units from my local supplier, total cost with our taxes just a buck or two short of $400.00. I waited a month and a half for them to get here and when I picked them up and tried them they did not work. Advice other than "return them: which I will do if I am sure it is not me messing up. So here is the story:
I have four microphones (lavs) two Trams and two Sennheisers, none are new but all work flawlessly with the only TR79 for Micron (Old Big 8pin Lemo) power supply I have left. I still use one of the old Microns and it works well despite its bulk with nice quality sound for some things. So rather than rewiire all 4 microphones with new 3.5mm Sennheiser plugs or some other configuration I decided to leave the Lemo 8pins on and use the TR79, try to find someone to fix the other one I have that is broken and use two of the EMP8L Ambient adapters to improve my usable mic inventory.
My guess is that the EMP8L is setup for negative bias other wise they should work and I can't for the life of me figure why they would do that. With positive you can use either phantom or a battery powered supply. With negative you are stuck with phantom and my mixer does not output negative just 48+.
So I know the guys at the supplier are going to be pissed to have to return these but if there is not other reason that these mics won't work they they have to go back. I know the mics work btw.. I tested them with the working TR79.
Thanks for any advice!
