Alzo HID Bulb and Ballast
homestar_kevin
Ok, So these have been on my radar for awhile thanks to this site.
Alzo is having the 15% sale through the end of January, spiking my interest.
I've never delved into HID or HMI type fixtures before, just based in Tungsten, Flo's and some crappy LEDs.
That said, I'm still just getting my head around this concept.
I buy the bulb and ballast, and can use them with essentially anything the bulb fits?
The bulb is a standard Edison screw?
I'm amazed by how much you could do with these, but the amount of possibilities just have thrown me off a bit.
Another random questions regarding these, I have Calumet Travelite 375r Strobes.
These have a separate modeling light and flash tubes.
Could I essentially put the alzo bulbs in to these strobes and convert them to continuous light sources when I needed too?
That would be awesome in terms of light modifiers, etc.
Thanks!
These are not the cats meow.
They are crappy 150w industrial HID bulbs that have a CRI rating of 85 but are really closer to a CRI of 72. They emit UV light and will need to use a UV shield to keep peoples eyes from getting burned.
If you want to do a low cost 150w DIY unit, pick up a high quality digital grow light ballast and an Osram 150w HMI lamp.
Are the Ebay grow ballast of a lot higher quality than the alzo ballast?
I know alzo isn't the greatest company in the world, and I had read the CRI rating thing in research into these, but I didn't know the grow ballasts were preferable.
I'm new to the concepts of these HID/HMI ballasts set ups, and am just trying to catch up and read up on them now.
The grow ballasts are the ones from ebay, correct?
Thanks for the advice, David
The Alzo HID lights work by sending a brief 3000V (or something like that) spike to activate the plasma. I don't know if other manufacturers do the same thing. The comments by David W. Jones sound pretty accurate.
I have several Alzo HID sets. The lamps are adequate, but vary a lot ( and some are really bad, but Alzo customer service is excellent) . I would not use them to light a skin tone. I use the ballasts now to run Coolights 150w CID lamps in a china ball and source four PARs. The color on those lamps is much better.
that said, someone on this board said his Alzo ballasts will not run his Coollights lamps, so there must be some variation there.
They will not work in place of your modeling lamps in the strobes.
you might want to look at the current LED options, there's tons of kickstarter/small startup options in decent price ranges. i'd rather have a current LED and deal with its quirks rather than a non-hmi hid
actually now that i recall, alzo has a decent single source led.... http://www.alzovideo.com/alzo-3000-high-intensity-led.htm
there's a thread on here somwhere, dustylense has them and vouches that they're very usable. there's also a near identical different brand on ebay
