Wave of Light said:One of the key things about the Arri lights is that they have such a well designed reflector and fresnel lens that the watt per watt luminance output compared to Moleis about 2:1.
-Charlie
MattinSTL said:How about that WEIGHT? Almost 2 pounds lighter then an Arri?
MattinSTL said:Also you gotta' have at least 2 or 3 dimmers. The camera dims the key... then the cookie shooter and the hair/rim need to be dialed in. You can get a world class looking interview with only 3 lights... easy. Sometimes even the hair/rim light is optional... then you are down to only 2 lights to make things look good.
If I'm shooting outdoors or in a daylight situation then I use my own flos. Some quick and dirty stuff gets the same treatment... depends on the shoot. If daylight is spilling in and I just need to make it appear to reach in farther then it is... again... my own flos.
