Alternative recording device?
MrBeaker
I wanted to know if I did not want to use the dvx100 as a recording device, could I firewire my canon zr60 and record on it to still get the same quality? :-/
The reason I am asking is because I want the dvx100 to last. I know It is kind of wired but I paid a lot for it and I am out of money to fix the heads if they go out.:'(
Another reason is I just filmed a short with some friends and they all liked to see the scene that was just shot. So I would show them the footage but I would have to rewind it.
I am just seeing if this is a good solution or a waste of time.:-/
Re: Alternative recording device?
Yes you could do exactly that. It's a little cumbersome but it would work. You could also record on both devices at the same time to give you the ultimate in protection against dropouts.
Thanks for the response barry. ;D I just thought it would be a good idea :D
I'm using a laptop PC to record the footage directly to hard drive (internal and external USB 2.0 or firewire), which also gives you a 15" HD monitor for instant review. As he mentioned, it is more cumbersome, and doesn't really work for moving shots, but for a fixed camera shot it's great.
Man, the head is not going to wear just like that.
You are even worse than me. I don't use the camera neither to rewind nor to play. No way!!! It is the precious!!!
But I do use it to record, though.
Anyway, all the best
Fidel.
Ya, i know it wont wear right away but i thought i would see what all ya had to say. :D
so thanks for all the comments. ;D
anyone tried to record to MJPEG straight out of the S-Video plug?
then the image would not be compressed to DV but could be saved uncompressed. you have to carry a shitload of harddisks with you, but it could be a far superior image.....
Good thinking, but it's not going to work. The compression to DV happens before the image hits the s-video port, IIRC.
The image would be compressed to DV, uncompressed, transcoded from component to Y/C (meaning the chroma channels are irretrievably blended together), sent out an S-video port, and then re-captured and recompressed in M-JPEG.
No, that's not gonna look better than straight DV...
when recording, does the heads of the dvx record better than a consumer camera? :-/
