Okay, for all of you Forum Fred's out there, I promise I will be seeking answers to my questions through the archives here. In the meantime, please help me out. I'm new to Premiere Pro/After Effects workflow and I'm not quite sure how it's done.
Using: AFTER EFFECTS 7 and PREMIERE PRO 1.5
All I want to do in After Effects is color correct my short movie. So I import the short movie project into AE. All of the files show up in the bin (Should I have done this?) Then, I drag my main sequence into the composition window. This is where I basically lose all my understanding of the workflow.
I drag my levels effect onto the sequence and color correct for the first shot. Buuuuuuutttttt... this then color corrects the entire short movie. I want to color correct each individual shot. Is this done with keyframes (taking the value down to 0 for every effect each time you reach a new shot?)? Cause if I have to lower and higher dozens of keyframe values every time I get to a new shot, that seems very unintuitive. So could somebody tell me the easiest way to color correct all the shots in a sequence?
Thank you!
Chris
p.s. i'll probably be posting lots of questions in here the next few days. So get used to me.
Thank you!
Chris
