CX350: AG-CX350 A.IRIS LEVEL - How to set a target level
TortiTakes
I apologize for what must be a basic question, but I am a newbie doing some live multicam work at some local concerts, I am trying to figure out how to bias the iris when using AUTO IRIS in MANUAL MODE (i.e., with the AUTO/MANUAL switch on MANUAL). When I turn on A.IRIS LEVEL I can adjust the exposure bias by turning the iris ring. I can see the level indication change (between -50 and +50) on the display, but I see no visible difference in the exposure as judged by the display brightness or the wave form monitor. I am not using SCENE FILEs. I just want to set a given exposure level and then let the camera adjust from there.
Can someone help me understand how to adjust the auto iris target level? Shouldn't I see some indication that the level adjustment is controlling brightness?
Thanks in advance! And again, I apologize for such a basic question. I don't see an explanation in the manuals.
1. The Iris can't open any further because it's at it's widest. The lens is variable aperture as you zoom the minimum increase in f/stops.
2. It can only compensate a small amount depending on area it's metering.
Thanks for your quick reply, Peter.
I noticed in the manual that I can adjust a target level to bias the auto iris above or below the “normal” exposure. It seems like I should be able to influence the exposure by adjusting a combination of settings related to A.IRIS, A.IRIS LEVEL, and A.IRIS LEVEL EFFECT. Unfortunately, I only have limited access to the camera immediately before or after a band performance, so my time for experimentation has been restricted, leading me to rely on manual exposure mode. However, the lighting conditions change so drastically and quickly that it’s challenging to adjust the exposure on the fly while moving around on stage during the band’s performance.
Last night, while reviewing the documentation again, I got the impression that I might need to use a SCENE FILE to store an iris level. Then, I can use the A.IRIS LEVEL button to enable or disable the exposure level set in the scene file. I’ll give that a try next weekend when I have access to the camera again.
