Gary Sconce
We needed a way to mount dual cameras vertically for our special effects shoot on green screen. We will be shooting with an HVX mounted sideways to gain pixels in the frame and also with a RED ONE to get access to the 4K. Both cameras had to be in the same column, not binocular in view.
I had old attic ladder steps, complete with rubber pads. I took three of them, cut them to size with my plasma cutter and welded them together in a 'C' shape. I then added 1/8" plate strengthened by 1/4" square stock underneath to the base to make it bulletproof (It will have an HVX and a RED on top... No droppie allowed!).
I boxed the base and plasma cut a hatch in the top of the base to have access to tighten fasteners on the tripod mounting plate. Here it is:
As all the sides are boxed it became very strong.
The variable mounting holes are at 3/4" centers and are for mounting an HVX sideways with either the screen up or down depending on the desires of the DP.
Here is the back of the plate.
This is the lone mounting hole on the base for an upright camera. It is directly under another above it for an exact match on vertical view.
Here is the base box opened showing the hardened plate in side with the mounting hardware fastener.
Here the top variable mounting holes for the RED (or whatever).
And finally, the variable mounting holes on the side to mount an HVX sideways again. I am hoping to test with camera tomorrow... If I can get away from set construction for a few...
