Gary Sconce
I am almost done with our slider for the next feature we will be shooting in the Spring and Summer of 2011. I needed it easily transportable, quick to assemble, solid, durable and versatile.
I needed a solid stucture to span the 8' and give a realistic 7' of slide to the camera. I wanted it to be attachable to tripods or able to be set near to the ground on short mounted feet.
"V" channel metal stock gives immediate rails for a coaster sled and also holds up a lot of weight. I purchased an aluminum 2"x2" 90 degree 8' long piece and then made two attachable ends for tripod or ground leg mounting. I found the aluminum was too soft so later purchased a steel version of the same size and length. Much better!
I took 4"x4" iron 90 degree angle stock and cut a 12" sled. I purposely chose a heavy sled to allow the GH1 to have a smoothing inertial movement and carry momentum. I mounted six durable ball bearing sliding glass door wheels to this sled. I attached a 2" camera deck to the top of the sled with 2"x2" iron stock and added two 1/2" square stock outriggers to hold the sliders that will mount the locking wheel rail. The underside locking wheel rail slides up and keeps the sled from ever falling off the V rail. I created a pendulum inertial lever arm that hangs down if desired, to completely stabilize the movement of the sled. This is optional and isn't needed for all shots.
The sled moves very smoothly and when mounted with one tripod slightly downhill, it can be released to cruise on its own. We will be using this on Troy Ruff's short in May.
I won't be doing a build for this as there are many slider designs with builds, including the amazing Zazaslider http://www.zazaslider.com
Just sharing this time.
Here it is, with the mounted inertial weight rig.
You can see, it is very simple
Here is the sled up closer. See how the heavy stock with its "V" shape lowers the center of gravity and adds stability to the slider? It does just fine.
I know... It is outside the box.. but it works very smoothly and can roll fast or slowly even with a large camera. Happy DIY-ing and best to you all! -Gary
rogar-Happy(DBG):
