After effects no longer opens
MiniMan13
I installed the illustrator trial to edit some templates i found, and now after effects doesnt open. Tried reinstalling twice, deleted the entire after effects folder and still wont work, any ideas?
Go into your Windows>Prefetch folder and delete the contents.
Can't hurt, may help.
Or, try unistalling AE again, defrag your drive, run Reg Clean, reboot, and install again.
If you recently installed another Adobe product, that is most probably the issue.
Unistall everything , defrag, run reg clean, install AE first, than Illustrator, and see if you have better luck.
If not, go with an older version of Illustrator, something like CS1.
Hope that helps.
Hope that helps.
I already tried most of that, i even made a user account just for after effects, and it still crashed, im in a time crunch so im going to have a friend render out what i need... But this really pisses me off that Illustrator would totally brick After effects, in the middle of a project.
