Ok, working in Premiere Pro CS6, I have Magic Bullet Colorista II?
In MB Colorista they have 'secondary' category which allows you to select the skin(by color and tone using a key) and applying whatever colorista settings you want to it, or you can invert the skin selection and apply the setting to the surroundings instead.
My question is, when applying a LUT(using lut buddy or something) is there a way to only apply this LUT to only the skin, or the scene(without the skin) Like you are able to do with coolorista by using 'secondary key'?
I don't want to use a 'mask'(where you draw an oval or circle shape) as it's not as acurate and the composition changes and the person moves to a different area of the image, then the mask will be off.
