stefanhuberfilms
Hi all,
I am currently developing a camera jib, specs so far: (in european dimensions)
suitable cameras: from DSLR's to a full rigged EPIC
max. camera weight: 15-20kg
length from Tripod to Camera: 1,2m to 2m
nice movements through plain bearings
telescopic design - the current design only supports the counterweights to be moved back and forth to achieve a nice balanced setup.
smallest size (for transport) 1,5m x 0,2m x 0,15m, should fit in a normal snowboard bag for example.
weight:
the first prototype we are currently working on is going to be about 14kg - made of Steel and powder coated. I would consider building it from anodized aluminium, which would result in a third of the weight, but would also decrease stability a bit.
you will need two tripod heads and one tripod
minimum tripod recommendation as jib stand: weifeng FT-9901 (this is the one i will test it on) see here: http://www.weifengchina.com/pro/index_show.asp?id=16
with a tripod height of 0,8m you will achieve a height movement from 0,1m to 2,5m from floor (calculated for a 1,2m arm).
So my questions to all here in DVXuser are:
should i keep a fixed length for the arm?
if yes, how long would be a comfortable length for you?
if no, what range would you like to have on a slide out arm?
(always talking about the length from stand to camera)
would you need a bowl for your tripod head though you can level the jib on the stand tripod?
if yes, what bowl size will you need?
of course i will keep the price as low as possible, what are you willing to pay for a jib like this?
please keep the price range of other jibs in mind,
please add a comment for what configuration your price offer would be (tripod bowl, camera arm telescopic, length, material)
will you need a brake that rotates with the jib (for mounting the camera p.e), or would a simple safety pin be enough?
please keep in mind that every additional option will result in a more expensive jib.
please post any features you would like to see on a jib, that makes the work with it comfortable and easy to use.
i will keep this thread updated as good as i can, i will post some pictures of the production and construction process here soon.
thanks in advance, and please excuse my weird grammar in some sentences
regards
Stefan
EDIT: changed the transport length to 1,5 meters
weight:
regards
Stefan
