have a 2009 Mac Pro. I think I may need to do a reinstall. Grrrr! Current Cuda drivers installed.
I’m editing .mts files from the card structure. Should i be doing this different?Just in case it hasn't been mentioned, CUDA does not currentlt assist H.264 decoding operations, thats still strictly CPU-dependant.
Are you using the MTS file Eric or are your wrapping them in a container with something like Clip Wrap?
Intresting. I’ll try that. My i7 MacBook Pro 17” was performing better than the Mac Pro so maybe that is it.Erik, have you tried turning the Mercury Hardware engine off and going software only? I have a couple of projects that I had to do that to, and, strangely enough, AVCHD performance was greatly improved.
On the 2009 it's set to cuda and the 2008 is software. Would the cuda card degrade scrubbing performance?
Thanks Petros.Nope, often ClipWrap will pass MTS files over to the Quicktime engine, resulting in degraded performance (at least last time I tried it) so that was a possibility. The way you're doing it is best.
