So whats this I hear about exporting some After Effects Filters into Final Cut Pro?
Do I just drag them into my FCP filters folder?
Will I be able to use then like the other factory filters?
Just wonderin
It should also be noted that After Effects works strictly in RGB color space, whereas FCP can work in both RGB and YUV (the color format used in broadcast). This is also covered in the manual.
