John Froton
Hi all,
I have an AKG Blue Line mic w/CK93 hypercardioid cap going into a MIXPRE and the MIXPRE outputs to an HVX200 XLR input. I monitor from the RCA outputs of the camcorder from the tape return input on the MIXPRE.
I set the 0db tone from the MIXPRE to about -15db in the camcorder and turned off the limiter in the camcorder as well.
From the MIXPRE I can monitor both from the camcorder's RCA outs and direct from the MIXPRE. The sound from the MIXPRE is much louder than the sound from the camcorder. Is this normal?
Also I try to keep the signal level of dialog at an average of -12db to -6db at the camcorder's meters. This seems to result in the MIXPRE's levels going above +4db to +8db occasionally. Is this okay?
I set both channels in the HVX to mic input 2 so I am getting mono sound from the mic on both left and right channels. Is this typically done?
Thanks for any advice
