advice on first real tripod
nho
so I'll be receiving a letus extreme, rails, shoulder mount, etc. etc. the whole package in a few days. while I do tend to shoot a lot of my stuff on my shoulder, I know that there will be times when I need a tripod. so, for an XHA1 with a letus extreme, rails, lens, possible monitor, what would you recommend for a tripod that is relatively low cost (used price) and that will be of the best use for me?
I should also mention that I have an indislider that I would like to continue using, if that's even possible when the camera because as bulky as it does with a lens adapter, rails, etc. -- so a removable head on the tripod that allows me to attach it to my indislider ( seen here http://www.indisystem.com/products/indislider_mini )
Everything hinges on what you consider "low cost"
some consider $200 low cost , others $500 and then some $1000.
then there are the guys that want $100 tripods...
where are you in this mix is the question.
right you are recordingwhiz, I should have mentioned what I'm thinking of spending. $200 is probably as high as I can go at the moment. hopefully that's not too little.
