texvanwinkle
Hey all. Saturday night I'm shooting a roast of/for a friend of mine in the private room of a local restaurant. There's a window wall on one of the long sides, but things don't get started till 7:00 (Central), so it will be mostly dark outside, fortunately. Even so, I asked them to put the roasters against the opposite wall facing the window. The room is probably 18x25-ish. There's bench seating all around the three common walls. The wall section the roasters will be standing in front of is 6-7 feet wide, with entrances on either side to come into the room. Ah, heck, I'll just draw you a picture (not exactly to scale, obviously).
The only lighting is small track lights several feet overhead, hanging from a warehouse-style ceiling. I'm obviously going to have to augment that, and that's where I could use some advice. I've never lit something like this before, and even though it's for a friend for almost nothing, I'd like to do it reasonably well, if only for the learning experience.
I have Rifa 44 & 55 softboxes with diffusers, as well as a ProLight and Omnilight with barndoors for each. I have no gels for the latter two.
I don't see how I can use anything very close to the speaker since it would potentially block sightlines, but I can't have lights on the walls because there are benches against them.
I have some ideas, but what do y'all recommend, based on my toolkit?
Thanks in advance.
Clint
Thanks in advance.
Clint
