Hi,
As mentioned in another thread on dvxuser I'm travelling to Cambodia and will be filming the work of an 'Aid and Relief' organisation. I'm still learning this craft and would appreciate any advice!
One part of the process will be recording interviews. I plan to record the audio separately and sync in post with Plural Eyes. Re: Audio capture, I'm still learning how best to do this in terms of microphone technique/placement strategy etc.
I realise that often people use boom poles and shotgun mics..but I am a bit reluctant about using a boom pole because I want to remain as discrete as possible and also will have novice help from other team members. (However I am open to all suggestions)
The gear I currently have available to me is:
Zoom H4n Audio Recorder
Oktava MK12 Mic
Rode Ntg1
DPA 4061 Lapel mic (wired)
Questions I am unsure about:
When recording interviews should I use the wired DPA Lapel mic? (In some cases I may be filming people who have barely seen a camera before...much less had someone strapping lapel mics to them!)
Should I instead use the Rode or the Oktava shotgun?
Would buying something like the 'Rode Pistol Grip' be a way of using the shotgun mic but being a little more discrete? Is this a good option?
Do i need to consider buying a wireless lav system instead ...is there something 'wireless' that can make use of the DPA 4061?
Any advice? What 'go to' techniques would you suggest?
Thanks for any thoughts at all!
Oktava MK12 Mic
Rode Ntg1
