Adobe Encore DND 1.5 question
dvxwheelr
When I try to build a dvd with Encore, I get the following message about half-way through:
"This image has sector headings. Hit OK if you would like to continue with the record with the sector headings removed."
What are sector headings, where do they come from and why do they have to be removed??? I used PPro to export my movies to the media encoder and then I imported them into Encore as assests.
I was burning a dvd. I found the answer and it is that I was using a copy protection feature that set up the sector headings (it was set to not allow any copies in the disk settings). When I changed the disk setting to allow many copies, the message went away. I still don't understand why they had to be removed though.
