Adobe CS6: Video missing in project
Anyanwu
Working on a project for a client. Downloaded assets from ftp server onto my harddrive. I can see and hear all the clips when I click on them individually on my hard drive.
When I open the project file he sent also via ftp that includes those clips, that I "Link Media" to assets that I have on my hard drive all I see in the CS6 project are green clips.
Everything in the bins and on the timeline is green. When I play the timeline or a clip in the bins I can hear the audio but I have no video just a green clip.
Does anyone have a solution to this? I am totally stumped and frustrated.
System: iMac
Mountain Lion OS X 10.8.2
3.06 GHz Intel Core 2 Duo
4 GB 1067 MHz DDR3
ATI Radeon HD 4850 512 MB
This is what it looks like:
Here is file information of clips I am working with. Project was shot with HDSLR cams.
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 5.55 MiB
Duration : 16s 810ms
Overall bit rate : 2 767 Kbps
Encoded date : UTC 2012-11-28 06:56:29
Tagged date : UTC 2012-11-29 22:43:28
�TIM : 00:00:00:00
�TSC : 24000
�TSZ : 1001
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 16s 767ms
Bit rate mode : Variable
Bit rate : 2 576 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.052
Stream size : 5.15 MiB (93%)
Language : English
Tagged date : UTC 2012-11-28 06:56:29
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Bit rate : 192 Kbps
Maximum bit rate : 249 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 389 KiB (7%)
Language : English
Mandla
