Adobe 4K video editing render times, need help
Jay2002
Good Morning All,
Last summer I built what I thought was a power house editing tower, But I am still getting really bad render times out of adobe CC 2018
My last video was just over 5 minutes and it took about 5 hours to render out. mostly 4K footage down sized to 1080 time line. One adjustment layer for color, some transition effects, noise reduction.
C drive is a 250GB SSD and this is where my adobe is stored. My footage is stored on the internal 3TB 7200rpm internal drive. I have saved it both to the internal drive one time and then saved it to the internal SSD with rendering times being about the same.
Export setting are H.264, VBR - 2 pass, Target Bit - 25, Max bit - 25, use maximum render quality
Even with some effects of the time line, I have to render sections out for playback to avoid lag.
I talked to some Youtubers who built $1,000 hackintosh and produce videos every day and have no problems.
Also, My lightroom is starting to lag, where it has never before. Only programs that were opened were, LR, PS, and youtube for music.
Anyone have any thoughts or can help out, I'm about ready to build / buy another computer, its just not fast enough.
Here's my parts list:
AMD - Ryzen 7 1700X 3.4GHz 8-Core Processor
MSI - B350 TOMAHAWK ATX AM4 Motherboard
G.Skill - Ripjaws V Series 32GB (2 x 16GB) DDR4-3200 Memory
Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive
Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive
EVGA - GeForce GTX 1060 6GB SC GAMING Video Card
be quiet! - Silent Base 600 w/Window (Black/Orange) ATX Mid Tower Case
EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply
I do not use Adobe but rather Edius. The CPU and video card are the two most important parts for rendering. CPU for video and video card for noise reduction etc... Your system is good but I would not call it a powerhouse. Maybe you can have a look at this Puget Sound comparison - https://www.pugetsystems.com/labs/a...aby-Lake-X-Broadwell-E-Kaby-Lake-Ryzen-7-969/
Ryzen is not bad but the laggard in the pack. I know that noise reduction is a killer without the biggest video card you can have. If you are into heavy video editing it is good to have a RAID for your video assets or a large SSD for the speed. Research a lot before you buy anything because performance only applies to your programs. You can get misled by other benchmarks etc... Know what Premiere needs and build the system around that. LR will be fine with whatever you put together.
You problem seems to be the GPU.
You write that if you take out some effects you have near real time playback speed, that implies if takes 5 hours only when you add those effects.
Also you make the encoding slower by using two pass encoding.
There is absolutely no point in doing a 2 pass encoding if you encode for YouTube, all it will do is to make the encoding slower.
The only time a two pass is necessary is when you have to fit a video to an exact size.
Good Point on the VBR - 2 pass. I am wondering if by some chance, Adobe is not recognizing my GPU and using what little card may be on the motherboard.
