Ryan Patrick O'Hara
Perhaps I misunderstood what you meant.
In this case, (light falling off from subject to camera) the inverse-square law does not apply to light reflected from the subject to camera. The subject becomes the 'source' of the light, and we see it, not the surface area where the light passing us (and camera) is hitting.
I think my approach to wording is the issue. I'll re-attempt.
The initial source makes light energy. The intensity of this light is subject to the inverse-square law... which is all about the beam spreading over a surface area. The larger the surface area of the beam, the more the light reduces in intensity. When light reflects off of the subject, it becomes the 'source'. Since we are looking at the 'source', our eyes are picking up the light as it passes us (to put it simply). This light always is the same 'brightness' no matter the subject to camera distance.
The inverse square law is in effect for the light coming off the subject, but we don't see that effect because we are looking at the source. That is where you are right.
So if I was disproving or proving you, depends on what you meant. Since the comment was juxtaposed when the conversation was regarding the light diminishing from subject to camera, I made the assumption.
All I know is that I've got a huge headache!
The first person mentioned that he thought the light halved from light to subject and then halved again from subject to camera, because light has to do the 'round trip'. I interpreted your comment was in regards (and in support) of that.The inverse-square law applies to light reflected from your subject, as well as any other light from any other source.
