DVX100Shooter
What is the best way to add an effect to ONLY a portion of a clip? For example if I wanted to put a strobe on the first 4-7 frames but have the rest of the clip playback normal. I have tried to select the clip then use my range tool and highlight a few frames then add the effect to just that portion that was highlighted. I even set in and out points for that same section of the clip as well but for some reason the whole clip had the strobe effect which I didn't want.
