Hello guys,
I've been using my Ultimate (EX1) for quite some time now and I wanted to clarify some basic usage questions.
1) Is it ok to use the camera's ND filters or to put filters on the mattebox ?
2) I get the strongest peaking pattern when both the camera's and lens's irises are full opened. When I start stopping them down the peaking start to fade away. Does this mean i'm loosing focus somehow or is it normal.
3) When I change focus on the 35mm lens from , let's say infinity to a few meters i notice that if i change a bit the focus on the camera the peaking pattern gets stronger ( The peaking pattern was already the strongest at infinity with the backfocus properly adjusted).
Does this mean that the focal plane changes somehow when changing focus ?
4) If you have an Ultimate, how high can you go with the shutter speed before seeing the grain on the GG. Mine can't go higher than 1/125 or 1/250 at 25fps. I think that at 60fps is even worse.
A test i've made to show this problem here: http://s4.transfer.ro/storage/transfer_ro-52fae2443c.zip
thanks
thanks
