ActionProducts NEW ActionCam Stabilizer Line-up
Justin R Goff
DVXuser Sponsor
Hello everyone! Innocinema is the North and South American distributor for ActionProducts, and we are proud to introduce the new ActionCam line up from ActionProducts. These rigs are state of the art, fully modular, industry standard, Swiss made of 7075 Aircraft Aluminum and Carbon Fiber, and can handle camera set-ups from 11-77lbs. These are ideal for most broadcast, digital cinema, film cameras, and 3D set-ups.
ActionCam RebelRed:
Package designed for the professional broadcast and lightweight cinema productions. Ideal for most broadcast, digital cinema and lightweight film cameras (REDone, EPIC, Alexa etc.). The RebelRed requires existing power supply based on 19mm rods (like "RED cradle", V-mount plate with 19mm clamp, ActionProducts "SwapPack" or similar solution), RED LCD (and its RED Arm) with cable (6ft required) and 2 19mm rods (min 8")
- 2“ / 50 mm diameter carbon fiber post.
- Industry standard gimbal- connector (19mm)
- Back mounted vest (50 lb) – One size fits all with left or right arm connection option.
- Industry standard arm connector
- Extremely high lift (96 cm / 37’’)
- 5 - 20 kg / 11 - 44 lb load
- RED power-cable (6 pin Lemo in post)
- Extendable carbon post (52 - 94cm / 20.5" - 37")
- (Optional: 60 - 122cm / 23.5" - 48")
- Docking-/Dynamic Spin Bracket
- Dovetail - Camera Plate»
- Swiss made with Aircraft 7075 grade aluminum
(Click for details)
ActionCam RebelPro:
Package designed for the professional broadcast and lightweight cinema productions. Ideal for most broadcast, digital cinema and lightweight film cameras (REDone, EPIC, Alexa etc.). The package includes its own power supply, monitor, a 2" extendable carbon post, the 50lb back-mounted vest, and everything listed below.
- 5 - 20 kg / 11 - 58 lb load
(Standard 11 - 44 lb + extra springs for 58 lb)
- «SwapPack» dual battery mount - (V-Mount, Anton Bauer or PAG)
- HD-SDI monitor: SWIT S-1070HS»
- (Optional monitoring available)
- 4 pin XLR universal power-adapter
- Monitor power-cable for PowerBox (D-Tap to 4 pin XLR)
- Composite/HD-SDI video-cable (post)
- (optional: 60 - 122cm / 23.5" - 48")
(Click for details)
ActionCam RebelElite:
Package designed for the Digital Cinema Cameras as (REDone, EPIC, Alexa etc.), 3D setups and film (35mm, 16mm) and video cameras. The package includes its own power supply, monitoring and a 2" extendable carbon post. Separate adjustable monitor mount, 100lb back-mounted vest and two external power splicers and everything listed below.
- Back mounted vest (100 lb) heavy-duty version – One size fits all with left or right arm connection option.
- 5 - 20 kg / 11 - 77 lb load
(Standard and heavy duty spring packages included.)
- RED extension power-cable (6 pin Lemo) for PowerBox
- Monitor power-cable for PowerBox (Lemo 2 pin to 4 pin XLR)
- Open end 2 pin 12 V Power-Cable for PowerBox
- Battery and Monitor-Mount separately adjustable
- 4x 19mm 12"carbon rods»
- 2x PowerBoxes»
(Click for details)
I almost forgot... See some of our rigs in action at NAB 2011 in this video from "Swiss Filmmakers"
Thank you! Stay tuned for more updates!​
Check out this behind the scenes footage take by Luke Rocheleau showing off the ActionCam RebelPro!
Please feel free to visit the build your own ActionCam listing at Innocinema!
We hope everyone has a happy and safe New Year!
