AAAh Help with removing pulldown
Matt Sconce
I have searched the archives and cannot find the exact answer I need. How do I re-insert the pulldown on export to go to DVD (Premiere Pro 2.0 on a 23.967 timeline)? :-( Thanks!:crybaby:
i'm going to presume you mean...you shot 24p advanced, used the pulldown to get 24fps to edit and now want to make a DVD and you want to create it at 29.97 so it will play? if so i don't think you need to do that, but you might want to check the settings of your export options. one way to check is export at 29.97 and see if anything goes wonky.
