hopkins802
Hey all,
I recently starting building out a small cage system for my Sony A7sii. Right now I have a the basic Smallrig cage that's made specifically for this camera. My normal setup will be handle on top, with a monitor mounted somewhere on top as well. The monitor I use, takes Sony NP-F batteries, so it's a little heavy on top. It's on rails that have a battery adapter plate mounted to it so I can power the camera with the large Sony NP-F batteries, this also helps balance out the weight on top. Everything's working fine, but I'm noticing that holding onto that tiny ass right hand side grip of the camera is causing the hand to cramp quite a bit, especially when it's just handheld, but even on a monopod. I'll be using this setup for weddings next season, so I'm trying to figure out the best way to make this more ergonomical for shooting long days.
Right now I have two ideas and would love to hear opinions / experiences.:
-1. The bottom of my cage can be taken off, and so I could buy the cheap knock off of the A7sII battery grip, and use that. However, those grips don't come with a battery door that's made for a dummy battery like the one on the camera is. So I'd need to either remove the battery door, leaving them exposed, or figure out a way to cut a small hole in the door to snake the dummy battery wire through.. Seems doable, but not sure it's the best option.
-2. I've seen these wooden handle grips that mount to the right side of a cage. They seem pretty good...But the whole reason I always have my hand on the right side of the camera is to have quick access to the mode dial, my custom punch in button and custom record button, which are all right there at a fingers reach. The wooden handle would at least let me carry the rig around a bit easier, but when operating, it may just get in the way...
Anyone have this issue ?
Thanks!
Dan
Thanks!
Dan
