A wide screen issue- help please
007liron
This was posted in the 'Output ...' msg board, but with no replies, so I'm posting here, hoping you can help, thanks.
I'm trying to export my film as a wide screen format, but there seems to be something wrong.
Here are the details of what I'm doing:
I shot with a DVX100b at 24p in Squeeze mode. Imported to FCP 5 as DV NTSC anamorphic, the sequence is DV NTSC (3:2) anamorphic.
In motion, the distortion is 0.
I export it to a QT conversion as DV/DVPRO NTSC as Interlaced 16:9. Size is 720X480, 'preserve aspect ratio' is unchecked.
The QT looks fine in the computer, the window appears to be at 16:9, and when I go to 'Full screen' mode there are bars at the top and bottom.
BUT- when I'm burning a DVD something seems to go wrong.
I'm using iDVD, define the project as 16:9, importing the QT I've created, and burn a dvd.
When I watch it on my tv there are NO top/bottom bars. When I watch it on the Mac's dvdplayer there are bars on the SIDES (rather than top/bottom) !
What am I doing wrong?
The DVD film should have top/bottom bars when played, right...?
(btw, I tried unchecking the 'Preserve aspect ratio' option in the QT file and then save it, but when I open it again it shows checked again...the pixles it shows are 853X480).
I appreciate your help on this guys,
Liron.
I just had a similar problem: filmed in HDV 16:9 I needed to export to PAL 16:9
only way I found: export movie as HDV 1080i then open in QT and export from there to DV PAL 16:9
