triplej96 Veteran Nov 29, 2007 #1 I learned AE before PS which is probably the opposite for most but I have a question regarding rotating or transforming layers. How would I rotate a layer to match perspective. In AE I would make my layer 3d and go from there... Any tips? thanks, Josh
MikeWilkinson Veteran Nov 29, 2007 #2 I don't think you have 3D layer options, but you can goto Transform, and then on your layer right click and select perspective/distort/skew/etc. If you want, try out the vanishing point filter and see if that helps. There may be another way that I am unaware of. All else fails jsut do it in AE and export a tiff with alpha channel.
triplej96 Veteran Nov 29, 2007 #3 Thanks for the quick response arges. I'll give those methods a try.
