liquidigital
Guys, I have Final Cut Pro 4.0, and cannot upgrade without getting the higher operating system. I have a Powerbook G4, but the ram needs to be at 384 for Final Cut HD, so here's my dilemma. I cannot effectively use Compressor and I'd like to be able to author a 24P DVD with MPEG-2 compression. On my Powerbook, it says "cannot connect to batch" something or other. On the support website, it says to download the update. Well the update makes Compressor not work with FCP4. You need 4.1 or higher to make it work. Again, the requirements are higher RAM. My export settings for Quicktime do not have it in FCP, but in Quicktime Pro I can export as MPEG-2. So what's the workflow here? Should I export from FCP4 with no compression (or uncompressed) as a quicktime movie at 23.98 and then export in Quicktime Pro as an MPEG-2? I hope you guys are following me, I'd like to not have to spend anymore money. Thanks for any help, Mike
