j1clark@ucsd.edu
Hi, and thanks for the reply.
Yep, I guess I should be more careful in my terminology..... I'm a COMPLETE beginner, I literally have no knowledge whatsoever....!
When I said 24p, I was really meaning "whatever that setting is that looks a bit like film"...if that means 25p because it's a PAL camera then I'll remember not to confuse the terms.
Anyway, so far I haven't been able to import ANYTHING into FCE. I have the configuration set to PAL/Firewire but I'm still having problems.
If it's any help I'm running OS X 10.4.11 with FCE 4 on a twin processor 1.8Ghz G5 Mac with 4Gb of RAM.
When I go to "capture" footage, I get the multi-coloured "PREVIEW DISABLED" screen, although there is SOME communication between the computer and the camera, as the rewind/ff/play buttons on the screen operate the camera....although the stop button has no effect and no footage is seen in the capture window..
Is it possible that the camera itself is transmitting some sort of timecode which is messing things up which I need to turn off?
Any help would be much appreciated, and in as simple terms as possible. The DVX is clearly a kicking camera and this community is somewhere that I want to become a part of but as yet ... I can't even get started!!! :zombie_smiley: Seriously, any help would be a major good thing right now....:thumbup:
I've not setup my DVX100 for capture in quite some time. The camera I now have been using until I can afford something like an HMC 150 (or whatever is the next new thing in that class...), is disk based, so I can easily transfer clips using the log/transfer menu. But for the DVX100, I'd setup to have the camera 'play', then I would click on the 'Capture Now' button to capture everything in one pass.
FCE does allow for setup to log/transfer in chunks, but because of my horror of using tape, I'd just capture the entire tape in one shot. I'd disable the 'stop on dropped frame', and set the limits such that it would capture an entire 1 hour tape completely. Typically I'd only go through a tape twice... once to record, once to capture.
Then I'd use 'find stop/pause' marks of FCE to then 'chunk out' the captured video.
During capture, there would be some hesitation on the video that was displayed, but the DV data was correctly transfered to disk... in otherwords my iBook was not capable of reading the Firewire, transfering to disk, and updating the video display all at the same time.
Others may have different practices... so don't take this method as the only one... it may be the 'worst' one for many situations... like maintaining broadcast quality since one would have to deal with the dropouts...
However, I was able to capture, edit, and output DV on my iBook which was very convient to carry around... and run off car batteries, in the middle of the desert... all the usual places where people do video editing...
