polecat
I have a premo Apple Pro Res 422 HQ rendition of my video that meets my highest standards....
I sent it to the compressor with DVD 90 Min best settings
Name: MPEG-2 6.2Mbps 2-pass
Description:
File Extension: m2v
Estimated file size: 2.94 GB/hour of source
Type: MPEG-2 video elementary stream
Usage:SD DVD
Video Encoder
Format: M2V
Width and Height: Automatic
Selected: 720 x 480
Pixel aspect ratio: NTSC CCIR 601/DV (16:9)
Crop: None
Padding: None
Frame rate: (100% of source)
Selected: 29.97
Frame Controls: Automatically selected: Off
Start timecode from source
Aspect ratio: Automatic
Selected 16:9
Field dominance: Automatic:
Selected Progressive
Average data rate: 6.7 (Mbps)
2 Pass VBR enabled
Maximum data rate: 8 (Mbps)
High quality
Best motion estimation
Closed GOP Size: 15, Structure: IBBP
DVD Studio Pro meta-data enabled
I put it through DVD Studio Pro
When I play it there is a noticeably pulsating semi pixelated two minute section right in the middle it that drives me nuts.
Is there something I am missing, or adding, that may be the cause?
A.
Description:
File Extension: m2v
Usage:SD DVD
Video Encoder
Format: M2V
Selected: 720 x 480
Crop: None
Padding: None
Selected: 29.97
Selected 16:9
2 Pass VBR enabled
High quality
A.
