a fun little question
Robert86
Carbonite Member
Hello eveyone!!!
Here's a nice little question for those who have dealt with this problem. So, I recieved my pelican case and foam today, I ordered two cases and some extra foam for a case I've had. I came home from work and started to mess with it, I made some spaces for my lenses and camera. But as I'm sure many of you have experienced, sometimes you take out a little more than needed, so that your equipment fits just a bit too loose. So most of the time you're like "god damnit, why couldn't you just get back in there and stay damn you!!!". Me too. The question is, do any of you have a method for putting your foam back in place, maybe with some glue or anything else. I just used some gaffer's tape but don't know how long that will hold.
when i got mine, they had an instruction, saying just use a little glue or something to put pieces back together. I forget what kind of glue, maybe a glue stick would do it.
Ok. I didn't know whether to use super glue or something else as I know that super glue can burn through things.
Rubber cement does the trick. To avoid overcutting in future use the toothpick method described in the instructions.
Cheers
Oh hey thanks guys. I'm sorry but I didn't have a chance to look at the instructions as I tried to get most of the carving done before I went back to work(from an hour lunch). I will go ahead and read the instructions. :)
