Nathyn
Low Budget Ninja
This is my first time in the DYI section as a designer. I do my own props but this is the first time I've done anything for my hardware. So today I'd like to introduce you to the TimeCode Mechanics Striker Pistol Grip. Seriously, it's made from parts of an old mechanical screwdriver I had laying around and old aluminum rod based shelf I found in the trash. The only part I paid for was the flat piece.
There were rubber cylindrical pieces in the shelf that screws went into so I took the broken metal in the screwdriver out and added glued that piece in with a massive amount of Super Glue. I also glued and tightened the top screw which secures the plank. Then I used another screw from the shelf (the shelf screws look like the top screw) to screw into the beachtek which I then screw onto the camera.
-Nate
-Nate
