B bagpipes6 Member Dec 10, 2005 #1 Would a clear UV 82 mm filter be recommended to be use on the HVX200? If so, regular rim style, or, the slim line style that would eliminate vignetting with wide angle shooting if this would be a problem?
evinsky Well-known member Dec 10, 2005 #2 B+W MRC is my choice. By far the best coating and a brass ring so it won't sieze like aluminum. It's worth every penny but will cost you $105.00.
Mr. Blonde RED Advocate Dec 12, 2005 #3 I'd reccomed a Hoya Super HMC Pro 1D filter, awesome quality, it'll cost u around $100. http://www.samys.com/product.php?ItemNo=HOYA82UVPRO1
G goober542 Well-known member Dec 12, 2005 #4 Does anyone know of a 82 mm step down ring, at least down to 72? (r)yan
khmuse Tech Guru Dec 12, 2005 #5 Here is a link for a 82mm to 72mm one: http://www.bhphotovideo.com/bnh/con...ls&Q=&sku=97289&is=REG&addedTroughType=search
