Hi All-
I'm a recent Vegas to FCP convert and needed a bit of assurance/advice on the best fcp secuence setup for mixed projects. I'm shooting with a Canon 7D in 1920x1080 24p mode, a Canon XH-A1 in 24F hdv, and a Canon HV20 also in 24f mode.
I've been playing around with some test footage and think I've got my workflow down for the most part. I'm capturing the 7D footage via the EOS plugin and rendering to prores 422 LT.
For the HDV material, I'm capturing into HDV, then sending files to compressor to convert into prores as well. I have yet to get FCP to capture the tapes any way other than manually starting the playhead and selecting 'capture now'. I'm also unaware if there's a way to capture from tape directly into prores. might not be an option.
Anyway, I'm still a bit confused with how I should be setting up my sequence. Do I use the easy setups that match the HDV? Do I set to prores? My test project was set up as HDTV 1080i, square, and ProRes LT.
I just feel like I'm missing something.
Also, does sequence setting make any difference when it comes to desired exports/deliverables? I'm expecting to create the following in any given project:
Std Def DVD
Blu-Ray
h.264 digital render
and some of the 'Share' options like ipad/etc.
Thanks for any insight!
Std Def DVD
Blu-Ray
