72mm UV
scotman
Hey, i just bought a 72mm UV filter to protect my lens. I got it from Best Buy. Did I waste my 15 bucks. Thanks Or do they pretty much to the same thing. I am using it with a M2 adapter. Please Help
You can get a normal U.V, but it is better if you can get a multi coated U.V. it helps to lower the lens flare.
I've see the difference of shoots wheni use it on my SLR.
That is why i spend a bit more on the HOYA (HMC)lens.
Here ia a site that shows you why you should get mulit coated lenses.
http://www.qualitycamera.com.au/product_info.php?products_id=1133
So cheap or not. it is o.k, as the main point is that it protects the camera lens.
