So what kind of lens can I use? Still photography ones? Or do I still have to use the really expensive for motion picture cameras?Sirius_Doggy said:72mm is the size of the filter thread on a DVX100 - so it would just screw onto the front of the camera lens.
Bayonet mount is the type of connection on SOME cameras that have removable lenses. I believe the Canon XL1 and XL2 have bayonet mounts so you would remove the lens and attach the device where the lens was originally.
Braskar said:Talking about guerilla 35 they mention that their product has two types of mounts 72mm and bayonet mount.
Braskar said:Will it matter if the lens is one orginally for still picture cameras or for motion picture cameras.
bvalente said:Still lenses were designed for 1-time setup and shoot. cinema lenses were designed for variable focus, so there is far less breathing in those.
Brian
thisiswells said:You may or may not know this, so I'll mention it. JBK Cine will make geared focus rings for
SLR lenses for like $70 per ring..
"Custom" Ring; They're cut down to size from a pre-fab molding for any lens.
Not affiliated with the guy and I don't like anything else he makes, but these don't look too bad.
Hope this helps.
JHouser said:Wow, that is great to know. Thanks!
J-
