azimov
Hi all, I have a strange problem with an animated short film I just shot with the DVX-100P. I shot the footage in 720X480. I altered this to 720X480 widescreen in After Effects. This is a standard AE output setting. The problem arises when I try to edit the composited footage into a film in Premiere Pro. PP doesn't seem to have a 720X480 Widescreen output setting. The rendered shots are blown up considerably with no black bars. If I play the rendered clips from AE on my computer they look fine. Black bars and all. But, when loaded into premiere, they get all screwy. I'd like to retain this 720X480 widescreen ratio (TV Letterbox) if at all possible. I understand that I'm working in sguare pixels on the ole computer, but I don't think I understand how 720X480 is horizontally smaller than 720X480 widescreen when they both have the same number of pixels. Though I can see that the widescreen image is indeed wider.
I can't seem to find a setting in the composition setup window in PP that will fix this problem. Any suggestions would be most appreciated.
