720 30PN viewing through Handicam (Noah?)
Jeff B
I have a Sony Handicam connected to my MacPro via firewire for capturing MiniDV from my HVX. I connected the composite video out of the Handicam to a 32" Toshiba LCD TV for clients to view as I edit. It's not a reference monitor... it's a way for them to be able to watch from the back of the room and not crowd me.
It works great with a SD (480 30p DV) timeline.
Recently, I shot in HD (720 30PN) with a P2 card. Everything looked great on the 720/30P timeline on my two 24" monitors but image the 32" LCD TV was about half the size with a black border around all four sides. When I click on a SD timeline it goes back to a full size image and then back to half size when I click on the HD. Any ideas.
I am ready to purchase the Intensity card by BlackMagic Design to go HDMI between the Mac and 3rd monitor. Before I do, can anyone think of a way to send this HD video through the SD firewire/composite camera at full size?
That's about as good as it gets- incompatible format/aspect ratios on the DV camera. Go with the intensity or one of the higher end AJA or BMD cards if you can.
Noah
Thanks for the quick reply!
The difference I see between the Blackmagic Intensity and KONA LHE is the Intensity has HDMI out and the KONA has component. If I don't need the I/O, is there a difference in what I will get out of the cards? If I need the I/O... would the Intensity Pro be the same? I am trying to understand what I am getting for 4x the cost of the Blackmagic card.
Funny, I picture you answering me in front of the edit station on your new P2 workflow video. I just watched it twice :-)
Speaking of the video.. I had 2 questions.
1. If I am the cameraman, capture person and editor for my own project and don't think I need Metadata, could I just rename the clips what ever I want in FCP as I log and capture directly from the HVX (p2 cards locked) and then drag a copy of all the new quicktime files from the capture scratch folder into an external drive as a backup before I start to edit. This would give me a safe second copy of the video and my files and clips would have some sort of naming that makes sense to me absent the metadata.
2. Is there a single or double P2 adapter that works with the MacPro like the AJ-PCD20P? I guess a double would come in handy with those clips that span two cards. I am trying to find a way to not have to bring my camera into my edit suite and have to worry about remaining battery time.
