NOMADIC
Major Contributor
So I had a broken mamiya 645, and I disassembled it, and used the lens mount and body inside the adapter I am building, its great because the ground glass was able to be mounted right at the film plane/lens focal point...dead on..
I used a 4" dia T shaped pvc pipe, it works great for mounting the body portion, and the achromat.
The problem is that I was a little off in my design, where I had planned to drill press the holes for the 15mm rails ended up screwing up the framing of the adapter to the camera. the picture attached explains what I mean.
Does any one know a good solution to make this work...keep in mind I am limited to building resources because I am in an apartment.
thanks!
matt
thanks!
matt
