Ed Kishel
I'm building a (very) basic backup system for my legal depo kit. My main kit will be an AC130a, a Shure MX367 mixer, and 6 balanced XLR lav mics with shielded cabling. It all meets NCRA guidelines- but I wanted an 2nd "emergency" kit should something catastrophic happen. I dont want to tell a client everyone has to go home 'cause I have technical issues.
The backup system is made up of hand me downs- a Panasonic miniDV AG-DVC60 (on AC power), 4 unbalanced Pyle electret condensor lav mics (1 AA powered), and a Radio Shack 4 channel mic mixer (9v batt power). It's all consumer stuff- but sounds suprisingly good. Not bad considering what I paid for it- $50 for the mics and mixer. It's bright and clear without much hiss or noise. For a backup I hope to never need- it works well....
...when I'm able to get rid of the hum I hear. It's faint and goes away when the cam is on battery power, but I have only 1 weak battery for this old camera, and want to use the AC adapter for power. This AC/DC adapter I'm sure is causing the hum. As I have already gone over my budget with my main kit- I want to avoid having to buy a bunch of new batteries for a kit I will probably never use. My goal for this backup system is that it never leaves my trunk.
I've gone through all the usual suspects- not crossing cables, checking the connections, isolating the power cords. It gets really loud when I touch one of the microphones. The only thing that helps is when I touch the chassis of the mixer or the camera's metal eyelet for the shoulder strap. The mixer does have a little screw on the back called GND. Is there something I can do- or is this standard for consumer gear like this. A link to a photo of the setup is below (if it helps).
thanks!!
thanks!!
