55mm 1 inch Spacer Ring
Passing Through
hy there everyone,
I'm searching for a spacer tube to use with my M2 redrock adaptor. The problem is that the company that's recommended by redrockmicro ( www.cameragear.com) doesn't ship to Europe.
So does anyone know where I should search for a similar spacer tube (=55mm 1 inch Spacer Ring)
Greetz and thanks
yep I'm looking for the same.
although I cant understand why the DVX100 would need a spacer tube when the DVX100A doesnt, I checked the stats and they both seem to have the same focal lengths.
my question to you dude, is why do you want 55mm? surely you want 72mm????
otherwise you're gonna have to step down and then step back up???
I just posted asking about the macro focus on the 100P because I cant find info on it anywhere.
I realised why "just passing" wants a 55mm spacer, because he has the SD macro lens. duh.
