i am working on a documentary series and im doing the edit in sony vegas ..part 1 is in a skate park and has made it into a film festival with the working print on the early bird round. i have about 5 months till the actual fest to finish. i dont know if i should do a 5.1 mix or stereo. i have been working it as a 5.1 being ambitious on my first doc. the reason is i figured i would pipe in some artifical sounds to get it a bit more depth since you get alot of outside noise . the film is about a skate park and its located under a downtown high way so you can imagine all the noise thats being pickedup. my issue is i dont really know where to sit the dialogue in the mix. everywhere i read says something different.. some say put the dialouge in the center of the mix and some say push it to the center and lt and right speakers .
i tested it with both 5.1 set ups and i get great dimension with the piped in sounds but my dialouge sounds thin and lost in the mix but if i take the same mix and turn it into a stereo mix it sounds great but it has no depth to it.
my concern is how it will sound at the festival. alot of the extra play is to mask the noise thats picked up because of the location. with it being a documentary im thinking people would be forgiving of the noise since its on location..
im coming up on my second production of a barber shop and i know im going to have to deal with the humming of the barber clippers and i was thinking of doing some of the same thing with it by piping in extra foley just to take away the distracting hum... ideally i would like to know how to eq that kinda stuff out or push it back.. so any advice on what any of you guys do to resolve that kind of issue would be great. i use a shotgun rode mic and i have lav mic . but i dont want to mic up the barber because i think that would grab alot of noise because of the proximity to the clippers and because the barber will be moving alot .
if you guys would like to see /hear samples from the two pieces i have excerpts online to check also.
