5.1 on CD-R for testing
toddburch
Hey all,
Came across an article at http://www.5dot1.com in the "Articles" section talking about how to burn Dolby Digital 5.1 audio files to CD-R(W) so that 5.1 mixes can be tested on a home surround system before baking a DVD (and creating a coaster if the 5.1 mix is no good).
I followed the instructions to the 'T' and while my home theater system read the CD-RW disc OK, it interpreted the 5.1 file as PCM audio and played back noise even though the system has a Dolby Digital decoder.
Has anyone been able to get this to work?
Re: 5.1 on CD-R for testing
Hey Todd,
Thanks for the pointer to the article. Much faster than my test method -- I took all the files into Vegas, did a rough mix then burned it to a DVD encoded with AC3.
As far as the problem you're having, one thing stood out in the article that may be stating the obvious, but here goes anyway:
You are playing the CD in your DVD player, right? The article says not to try playing it in your CD player. But I also see he warns that even when playing through the DVD player, you may still get an "as is" playback.
Happy Holidays!
Phil
Hi Phil,
Happy Holidays! Thanks for the reply--I was indeed playing through the DVD player with no luck. Have you tested the method in this article to see if it works for you?
-Todd
Hey Todd,
I figured you had, but it never hurts to check.
I'm going to be giving it a try this week. I'll let you know what I find.
Phil
I always test on a DVD-RW. I already have too many coasters lying around. ;D
