i believe you only have to scale up as far as 133. and if you want to keep the geometry of the frame from looking squished or stretched, i wouldn't distort it and just deal with losing picture at the top/bottom of the frame. but if the geometry is of no concern, then a setting of 33.33 (or -33.33, i forget which) will precisely size the 4x3 original to a 16x9 frame.heartajack said:I discovered an interesting way to do this. I took the 4x3 sequence into another sequence and scaled it. In the motion tab set the scale to 140 and then go into the distort section and change Aspect Ratio to 40. This will give you the desired squeezed video that plays perfectly on a 16x9 display.
I get an error page with that link.CaptainMench said:http://web.mac.com/captmench/iWeb/Site/FCP Tutorials/FCP Tutorials.html
Check out the newest tutorial -- Mixing Aspect Ratios
CaptM
Blaine said:I get an error page with that link.![]()
